Old 08-09-2006, 01:24 AM
mustang67408's Avatar
KE7WLF Master of Disaster
Default Re: Rx300 O2 Sensor Problem (bank2, Sensor1)
Originally Posted by smsydnor
HELP! I need to get an O2 sensor for bank 2 sensor 1. However, when I call around to see if anyone has this part in stock no one seems to quite understand what I need. Can someone let me know how to convey which O2 sensor it is that I need. Also, the code that is coming up is P1155 (A/F sensor heater circuit bank 2 sensor 1). If anyone can help me I would appreciate it.
What you need is NOT an 02 sensor, it IS
DTC P1155 A/F Sensor Heater Circuit Malfunction (Bank
2 Sensor 1)
There is a difference and they are not interchangable.
You need the Upper sensor (before the cat) on the bank of cylinders closest to the radiator.
Print this picture and show someone.
The part number is printed on the sensor itself. Very tiny, but it's there.
25 yrs with TOYOTA
