Old 08-15-2006, 08:07 PM
TomWS TomWS is offline
Last Online: 06-28-2007 08:27 PM
TomWS may have some regrets.
TomWS's Photo Albums
Default 2000 Echo, Check Engine, P0420 code
Hello. I've recently purchased a 2000 Echo with just over 100k miles.
The check engine light came on last week and I attempted some fixes (change air filter, clean MAF sensor) and reset the codes before having them read.
The light came back on after about 15 miles so I had Auto Zone check it. It returned two P0420 (those are zeroes) codes which stated on the machine that it was an inefficient catalyst issue, or something near that. They suggested to replace the catalytic converter, but some reading hinted at trying the "downstream" O2 sensor first since it could send the same code and it's cheaper.
I replaced the sensor today and cleared the codes only to have the light come back on before I'd run 15 miles again. I had Auto Zone check it again and it still returns two P0420 codes.
Before I give in and shell out the funds for a catalytic converter replacement, I wanted to check here and see if anyone has any other suggestions on what it might be. It's bad enough losing $130 on a sensor, but I'd sure hate to drop a load on the converter and that still not fix it.
Thanks in advance.
