Originally Posted by tobiasgriffith
I already returned that parts and, you were right, they were not the original manufacturer parts.
For now, I'm holding off on buying the new oxygen sensor (manufacturer part) because I'm not so sure that this was the real problem with the car now. Do you think this is ok? Or should I change the Oxygen sensor anyways. I don't remember the exact code it gave but it said something like, "bank 1 too lean".
I will drive it a couple more days and see what's happening.
Thanks again for all your help.
IF IT'S NOT BROKE DON'T FIX IT.
It was probably code P0171, That is usually the MAF sensor. Cleaning fixes it MOST of the time. I would drive it and see what happens.
If the light comes back on, Get the code scanned and tells us here at TS so we can help you diag the problem. I think you fixed it already
25 yrs with TOYOTA
