Old 08-31-2006, 06:52 AM
schmidtj schmidtj is offline
Last Online: 09-02-2009 04:01 PM
schmidtj is on a distinguished road.
schmidtj's Photo Albums
Default Re: Dead fob w/ smart key? 07 camry hv
Originally Posted by elsapo View Post
Just wondering whats the procedure if your fob is dead w/ smart key?
Actually it's covered in detail in the manual.
First you should get a warning message on the MFD (multi function display) well in advance of it going "dead". Even if it goes dead without warning you merely use the mechanical key to gain entrance through the driver's door, depress the brake and hold the fob with the dead battery up nead the start button. When the start button's LED turns green press the button and you should be good to go. Then replace the battery.
Hope this helps.
J
