Old 09-06-2006, 10:10 PM
ca32174 ca32174 is offline
Last Online: 09-13-2006 01:58 PM
ca32174 is on a distinguished road.
ca32174's Photo Albums
Default Re: Need Speaker for 2000 Avalon JBL
In order to remove the subwoofer you have to first remove the 3rd brake light housing which is located just below the rear windshield. You simply just pull it up and forward with your hands....very easy to do...once loose you then disconnect the rear 3rd brake light cable and remove the beige plastic housing. Then you need a 10mm socket to remove the 4 retaining bolts that hold the oem plastic speaker holder in place. Make sure you disconnect the white connector that gives power to the speaker. Once removed there are 4 more phillips screws to remove a mesh screen that sits on top of the speaker and releases the speaker from the plastic holder. The outer frame diameter of the Kicker speaker is 8.5".
