Old 09-23-2006, 08:29 AM
vintage42 vintage42 is offline
Last Online: 07-24-2008 06:30 AM
vintage42 may have some regrets.
vintage42's Photo Albums
Default Re: Octane and Power
Originally Posted by SuperBusa View Post
Only if the lower octane and driving conditions make the engine knock. If the engine doesn't knock then the knock sensors do not detect anything and the computer doesn't retard the timing. You will usually hear a couple of knock before the computer reacts, so if you're not hearing anything chances are the timing is not being retarded.
Knocking can be hard to hear. If you can hear it, it takes a second to recognize what it is. At high rpms, it sounds like pinging or grease frying, and hundreds of knocks can take place before you are aware of it. This is with old engines.
With our modern engine, a knock is sensed instantly and the ignition retarded. From the Scion xB Tech Literature:
DIAGNOSTICS - SFI SYST
DTC P0325 - KNOCK SENSOR 1 CIRCUIT - CIRCUIT DESCRIPTION
Knock sensor is fitted on the cylinder block to detect the engine knocking. This sensor contains a piezoelectric element which generates a voltage when it becomes deformed, which occurs when the cylinder block vibrates due to knocking. If engine knocking occurs, the ignition timing is delayed to suppress it.
Knock sensors sense a knock before we can:
"Most of today's engines have... knock sensors. Spark is automatically advanced until knock occurs and then is backed off slightly. The sensor detects engine knock long before your ears..."
--Trailer Boats, Oct 2006, Tech Letters, page 72.
The xB Owners Manual, Section 2, Page 114 says:
OCTANE RATING
Select Octane Rating 87... or higher.
Use of unleaded gasoline with an octane rating or research octane number lower than (87 octane) stated above will cause persistent heavy knocking. If it is severe, this will lead to engine damage.
So if we ever hear knocking from our xB engine, it means that either the octane is lower than 87 or the knock sensor has failed.
On octane lower than 87, the ECU receives the signal from the knock sensor to retard the timing, but will not retard the timing enough to prevent knocking. Evidently Toyota decided the engine will not run properly with that much retard. Too much retard makes engines run sluggish and hot and not reach high rpms.
