Originally Posted by jeff_o
wow... i never knew that... the only cars with heater i know are the old diesel engine ones with engine heater... they say it heats up the diesel petrol for quick combustion during cold starts. They make an electric heater and one that uses coolant to keep the fuel warm for better starts and better acceleration cold but i never knew cars have electric heaters... are these only for diesel engines as well?
The block heaters are for gas or diesel engines. There are companies that make them for many models. It keeps the coolant warm.
I had a 1987 FORD 4x4 ,6 clyinder (gasoline). I added a block heater to it, many years ago, so when I started it in the morning for work, the heater was already blowing warm.
I have seen many toyota gasoline engines with an engine block heater as well as a few diesel. Not to many diesel Toyotas here in the states.
25 yrs with TOYOTA
