Originally Posted by jimb1300
Hi, a little help please... I understand this fluid is coolant for the inverter similar to the engine coolant. What would be the effect of adding brake fluid to the inverter fluid. This has occured on my 02 Prius....Thanks.
If the brake fluid is not flushed out it MIGHT swell all the rubber hoses and affect the PLASTIC INVERTER WATERPUMP. It all depends on how much was added, Did the coolant absorb the brake fluid like water does?
I would not take a chance on it.
I would have someone who knows how.... flush that system.
The Inverter coolant system is very difficult to service as it will develop
an air pocket and has to be bled out. It takes usually in excess of 1 hr to do this time consuming job.
25 yrs with TOYOTA
