Old 09-30-2006, 10:50 PM
spleck spleck is offline
Last Online: 07-17-2009 10:54 AM
spleck is on a distinguished road.
spleck's Photo Albums
Default Re: Tire Pressure Warning
Originally Posted by flyingn View Post
rotating should have no bearing. My guess is that the dealer is adjusting the pressures after rotation. If not you have a defective sensor
I've been checking into this, and from what I'm seeing, the 2004 RAV4 doesn't actually have pressure sensors in the tire. They're using the wheel speed sensor. If true, this would explain how a rotation can throw off the sensors (if your tires are slightly different diameter). Has anyone watched their tire get mounted to see if there is a sensor in the tire?
PD008-03 INITIALIZATION OF TIRE SENSOR WARNING SYSTEM DURING PDS (REVISED)
11/11/2004 - 2004, 2005 Toyota RAV4. While the vehicle is in motion, the Tire Pressure Warning System (TPWS) monitors the wheel speed signals that are output by the speed sensors for the brake control system. The system uses the resonance frequency method and the relative wheel speed method to detect low tire pressure in one or more of the tires. The resonance frequency method detects a change in the resonance of the tires that is caused by a low tire pressure based on the total value of the wheel speed signals that are output by the four speed sensors. The relative wheel speed method utilizes the changes in the wheel speeds that occur when the actual radius of a tire decreases due to a low tire pressure.
