Re: 87 Toyota Van manual trans. clutch
There is no clutch cable. You probably felt the speedo cable.
It uses a hydraulic clutch master cylinder and a hydraulic slave cylinder.
Remove negative battery cable
Remove The instument finish panel (5 screws)
Remove combination meter (speedo head assy)
Remove air ducts #1/2/3/
Now you can see the clutch master cylinder, it gets brake fluid from the brake master cylinder. Look at the top of the clutch pedal is there fluid?
Look under the vehicle and find the clutch slave cylinder. Is it leaking?
Hope this helps
25 yrs with TOYOTA
