Old 10-11-2006, 09:57 AM
mustang67408's Avatar
KE7WLF Master of Disaster
mustang67408 has blessed us with their presence. mustang67408 has blessed us with their presence. mustang67408 has blessed us with their presence.
Default Re: 87 Toyota Van manual trans. clutch
Originally Posted by The Fish Genius View Post
Thanks so much! That makes sense... you're a Scooby Van Guru. http://www.tundrasolutions.com/forum...hanx_Smile.gif
Any advice on bleeding the clutch?
Thanks again,
George
Use a helper
1 pumps the pedal and keeps the fluid level up in the resovoir
1 opens the bleeder screw
Use a clear bottle and a small rubber hose on the vleeder screw on the slave cylinder (undervehicle)
If the system has a mush pedal as you describe , you probably need a clutch master and you might as well change the slave cylinder too.
If there are no leaks, you've bled the systemand the pedal still feels funny then the clutch pressure plate may have gone south.
Good Luck
p.s. YES, I remember these vans when new
24 yrs with TOYOTA
Discounts on Toyota Parts <---PM me
