Re: Installed my Hellwig today :)
I agree the Helwig Sway bar makes a huge difference. I took me about an hour or so to install. I did have to modify one of the bolt sleeves since it was about a 1/4 of an inch longer than the other and I could not get the bolt on. As for fit...how close does your sway bar sit from the pass. shock mount? Mine was less than 1/8 of an inch and it sometimes rubbed. I talk to the guys at Hellwig an they told me on some tundras there is a clearance issue. If you do have this probelm send them an email and they will send you spacer brackets for free.
O6 DBL Cab Limited 4x4
Weld Cheyenne 17x8.5 with 4.5 BS
285/70/17 Toyo Open Country AT
RevTek 2.5 Leveling Kit...1.25 Block in Rear
Hellwig Sway Bar
3M Clear Shield Bra
Volant Cold Air Intake
Magnaflow 12256
Bully Bars
Viper 791-XV
XM and my Garmin Nuvi
