  #31 (permalink)
Old 10-16-2006, 05:47 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Default Re: Starter / Replacement Contacts
Originally Posted by DevinSixtySeven View Post
would it help if i pulled the fuel pump fuse, let the engine die, then disconnected the fuel line? so as to reduce pressure in the line when i disconnect that 22mm nut?
That's a good idea
I just place a rag around it a crack it open slowly. Let the rag absorb the fuel.
25 yrs with TOYOTA
