Originally Posted by Ando140
Thanks for the help guys, I'll give you an update as soon as I can get my dad to actually work on it... could be weeks...
well i had the same problem before run's for a minuite then die's but when it dose run sounds ok it will rev up then die. so if this is the problem. there is a ground wire for your injectors it will only put gas in when u first turn key then will stop. i missed it while i put in my new engine so u should check that out. mine was supost to be by the theromstat houseing but waas not connected.
