Originally Posted by wheeling
well i had the same problem before run's for a minuite then die's but when it dose run sounds ok it will rev up then die. so if this is the problem. there is a ground wire for your injectors it will only put gas in when u first turn key then will stop. i missed it while i put in my new engine so u should check that out. mine was supost to be by the theromstat houseing but waas not connected.
We'll check that one out... believe it or not, its still not running (though we haven't worked on it for awhile). Thanks for the info.
And yes, what you described sounds exactly like the problem we're having.
