Originally Posted by wheeling
well i had the same problem before run's for a minuite then die's but when it dose run sounds ok it will rev up then die. so if this is the problem. there is a ground wire for your injectors it will only put gas in when u first turn key then will stop. i missed it while i put in my new engine so u should check that out. mine was supost to be by the theromstat houseing but waas not connected.
Well, we looked at it... that ground wire (and every other ground wire we could find) were already attached. We even verified continuity using a multi-meter...
Wouldn't happen to have any other ideas, would you?
