Re: how to change stereo in yaris
As a SUBSCRIBER, you will have access to all of the PDF's seen. The knowledge base is full of valuable information.
If the PDF's are not there, ask a moderator or TS Support and they will be provided if available.
25 yrs with TOYOTA
