Old 10-20-2006, 06:29 PM
bikol-ini's Avatar
bikol-ini bikol-ini is offline
Last Online: 08-20-2009 12:56 PM
bikol-ini is on a distinguished road.
bikol-ini's Photo Albums
Default File a complaint to NHSTA regarding VSC/ABS Skid control ECU failure
hi, did somebody file a complaint to NHSTA regarding this skid failure failing and making your vehicle uncontrollable due to sudden cutting off or preventing you from accelerating, I suspect that this is also in conjunction with the quite a while TSB regarding upgrading your brake caliper and rotor, thus having this upgrade throws off the syncronisity of the old brake/caliper combo versus the newer brake upgrade, so for the skid ecu to see a newer upgrade the skid vsc ecu should be reflashed or reprogram or un upgrade of the skid ecu, this is just my opinion after reading all the complaints about this particular ecu which is prone to failure on the 01-02 sequoia or tundra in internet chatrooms or forums like tundra solutions and edmunds.com,
anybody thought about this,
1981 Toyota Celica GT 486000 mi original engine/tranny with 79 Supra F312 rear
1996 Lexus LS 400 210000 mi and going strong
2002 Toyota Sequoia SR5 4WD 80000 mi too young
