Old 10-23-2006, 04:58 PM
v8Toilet's Avatar
v8Toilet v8Toilet is offline
Last Online: 08-20-2009 06:58 PM
v8Toilet is on a distinguished road.
v8Toilet's Photo Albums
Default Re: MPG!! I've got to eat crow!!!!
My secret is I have 2WD, weigh in under 4400 lbs, have a tonneau cover, use all synthetic fluids (engine, trans, diff), and I have some breathing modifications. I also had a new Toyota air filter in at the time of the test.
My mileage was achieved traveling at 65 mph with the cruise control on and I was about 200 ft above sea level. 22.7 mpg was the best I have ever got with a few 21 mpg in there too.
If I go 70 + mph I値l only get 18.5-19 mpg.
If you have 4WD you値l take a highway mileage hit because 4WD trucks are higher off the ground, weigh more, and have more mechanical parts to move with more inertia even if your 4WD is not engaged. If you have a cap or no tonneau or bed cover you値l have more aerodynamic drag. If you drive with your tailgate down you値l have more aerodynamic drag. If your tires have high rolling resistance you could get up to 2-3 mpg worse gas mileage according to Consumer Reports. I bought tires with very low rolling resistance. If you have low tire air pressure you値l get worse gas mileage. If you have a dirty air filter you値l get worse gas mileage. If you have a K&N or TRD air filter you値l get slightly worse gas mileage. If your 02 sensors are getting sluggish you値l get worse gas mileage. If your engine tends to ping on 87 octane and the knock sensor retards the timing as a result of that you値l get worse gas mileage. If you have bigger tires or a lift kit you値l get worse gas mileage. If it痴 cold outside you値l get worse gas mileage because your truck will take longer to warm up. If you use the A/C or drive with your windows down you値l get worse gas mileage. If you drive with all your lights on you値l get slightly worse gas mileage (the fog lights each are 110 watts!) If the wind is blowing against your truck while traveling you値l get worse gas mileage. If it痴 raining out you値l get worse gas mileage. If you have dragging brakes you値l get worse gas mileage.
I think that痴 it!
stock exhaust
TRD LSD
Extang lift off tonneau
Hankook DynaPro AS RH03
stock air filter & box
220 HP @ 4800 RPM
302 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, stock air filter, and JBA headers
208 HP @ 4800 RPM
285 TQ @ 3400 RPM
Run With Spintech Sportsman XL muffler, TRD air filter, and stock manifolds
204 HP @ 4800 RPM
271 TQ @ 3400 RPM
Bone stock
Dyno run results click here
