Originally Posted by mitey_whitey
I have been dowloading from techinfo.toyota.com all morning....
I found lots of great electrical stuff, but am still trying to find "THE MANUAL" that has pics and breakdowns like you posted with instructions.
Under the repair manual section there is some pretty simplistic DIY stuff, but not the shop stuff. Did I create the wrong kind of account in setup?
This is how I found the pics I posted and some of the instructions, most of them were from memory. I did a SEQUOIA starter yesterday (30min
start to finish
START HERE:
TIS
Vehicle: 2000 Tundra
REPAIR INFO: repair manual
Section :Starting (2UZ-fe)
Sub section : STARTER
CLICK "FIND"
THEN CLICK REMOVAL. In that PDF that pops up there are other links (SEE PG SF34) (see page EM34) for removing different components. It tells you to remove way to much stuff. I pick and choose what components to remove, there is no "MANUAL" or exact step by step, like what I posted.
They assume you have working knowledge of this entire vehicle and dont need a post of exact step by steps for all things.
I have TIS thru the DEALER at work and the same account at home. I dont know what accounts are avaliable to the general public.
24 yrs with TOYOTA
Discounts on Toyota Parts <---PM me
