  #25 (permalink)
Old 10-30-2006, 02:26 PM
evanstolze evanstolze is offline
evanstolze's Photo Albums
Last Online: 10-31-2006 01:07 PM
evanstolze is on a distinguished road.
Default Re: 2000 echo check engine light
Originally Posted by Siriusarcher View Post
Howdy
My first post here...
Thought I'd share what I've learned recently about the fuel delivery system in this car: Had the check engine light, with poor idling, poor acceleration (bogging when I hit accelerator), and occasional stalling at idle, which is a huge safety issue given the vacuum assist brakes and power steering.
Brought to my mechanic who found the p0172 (rich on fuel mixture). He diagnosed a failed O2 sensor, which was replaced, to no effect. After that, he recommended a new throttle body assembly thinking that the idle motor or throttle position sensor was pooched. These can't be fixed--gotta replace the whole TBA. I went to dealership, bought and installed the part, reset EFI, all to no effect. Finally, on a whim, I pulled the mass air flow sensor out (small philips screwdriver needed), cleaned it with a thimbleful of rubbing alcohol, a q-tip and shot of compressed air. Re-installed and reset compter (pulled EFI fuse B). Voila! problem solved! No bogging, better mileage, no stalling. Could have saved about $700 if I had tried that earlier. Consequently, I've got a perfectly good throttle body assembly sitting on my work bench. Anyone with similar experience?
I'm having a similiar problem, and have now removed, cleaned, and replaced the MAF. Where do I find EFI fuse B so I can reset the computer and clear the code (the check engine light is still on)?
Thanks for your help.
