  #28 (permalink)
Old 10-30-2006, 10:13 PM
mustang67408's Avatar
KE7WLF Master of Disaster
mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light. mustang67408 is a glorious beacon of light.
Default Re: 2000 echo check engine light
Originally Posted by evanstolze View Post
Thank you. Unfortunately, after cleaning and reinstalling the MAF, the problem is now worse. Previously, the car had almost no noticeable driveability problems (slight hestitation on acceleration when the engine was cold). The only issue was the check engine light would not stay off (I had it cleared twice by a dealer, and each time the code read something like " lean on bank 1 " ).
Now, the light is on, and the engine cuts out and shudders badly when you apply the gas. If I baby the throttle, I can drive the car.
Any ideas? I don't see how I could have done something wrong with the MAF...
The check engine light initially came on immediately after filling up at a station that had run out of gas. I had to wait for a tanker to top up the tanks before I filled up. This was several tanks ago. When I took the car in, the dealer suggest replacing the fuel filter, and if the light did not go off, the Oxygen censor, but I have the impression he was guessing.
Thanks again for your help.
Personally I would drain the fuel tank, change the fuel fileter and flush the lines.
Waiting for a tanker is not a good idea, all the CRUD in the tanks settles to the bottom and when the tanker fills the tanks, all that CRUD gets mixed into the fuel and is pumped into your tank.
NEVER GET FUEL FROM A STATION THAT IS FILLING ITS TANKS. You have to wait a few days for that CRUD to settle. I always tell people to learn the gas stations habits of when they get fuel.
The only real way to hurt the MAF is if you use an aerosol can and spray it point blank, sometime the resistor for the AIR INTAKE TEMP gets broken.
Without me having a fuel sample,or scan tool readings, thats my best GUESS.
25 yrs with TOYOTA
RENTAL VEHICLES
