Originally Posted by evanstolze
Thanks Mustang, I had a feeling you were going to say that......lesson learned. I also suspect I may have damaged the MAF - I did exactly the wrong thing (thinking I was being thorough), and sprayed cleaner from an aersol directly into the MAF.
Usually people dry them with compressed air and that usually ruins them.
I would try draining the fuel and changing the filter and flushing the lines then replace the MAF if it still throws a P0171 code.
Do NOT USE E-85 fuel either.
