I got a 07 Rav4 base model with no fog lights. I plan on installing a set, and I see that you folks might have some ideas. I planned on just adding a switch in an open dash knock out, but is there a easy way to install the factory type switch? I currently do not have the fog light switch on the signal lever. I am assuming that since i do not have that switch, i also do not have the fog light wiring that many of the RAV4's come with, even without the fog lights, and if i did have it, it would be very difficult to install it and hook up to any wiring in the steering column. Anyway if you have any ideas please let me know.
I also plan on installing some rear backup lights. I was going to install a set of 50 watt halogens, but i would have to run more wiring to the hood area, so i am planning on getting some LED's
PIAA they look like they are under 10 watts each and i think i could splice them straigh into the existing backup lights and not need a relay or much wiring. Anyone have any suggestions or comments?
