  #20 (permalink)
Old 11-03-2006, 11:01 AM
Sanchez's Avatar
Sanchez Sanchez is offline
Sanchez's Photo Albums
Last Online: Today 12:28 PM
Sanchez is on a distinguished road.
Default Re: Rear Window Dead?
I had the rear window dead for 2 years.
It started off intermittent.
It would work on some days and others it would not.
I suspected it was short in the system or a bad window motor.
After a few months it just stopped working.
I was out of warranty I left it alone. Did not use the rear window all that much anyhow.
THEN!!!!
I read the TSB about it.
And after 2 years well possibly 3..... THE WINDOW WORKS NOW.!!!
I simply removed the Spring and bracket as mentioned in the TSB.
Its been 2 weeks now and Not a Problem.
Who would have guessed?
Anyhow, for those of you with similar troubles try to remove the spring and bracket.
Its easy and quick.
Only took me about 20 min.
To remove and replace everything.
2001 Sequoia 2WD SR5
Mods:20s wrapped w/ 295/45/20
Borla Dual Side Exit Cat Back Exhaust
OEM Foglights Install
TRD Drop-In Filter
