Originally Posted by MWK
I have a 2000 Soalra with a check engine light and no aux fans. Do you have any ideas on where to start trouble shooting?
Thanks
MWK
When was the last time you had your car serviced? Might be an O2 sensor - or something loose under the hood. Check for the obvious things first (obviously)
- might be a vac leak or even something goofy with your ECU (computer).
I think some stores like Autozone have a device that reads codes and can tell you what it is specifically - if you don't find something on a quick physical inspection.
Jeff
