  #32 (permalink)
Old 11-07-2006, 11:10 PM
mustang67408's Avatar
KE7WLF Master of Disaster
mustang67408's Photo Albums
mustang67408 will become famous soon enough.
Default Re: 2000 echo check engine light
Originally Posted by elev8 View Post
Hey yall, rookie to this board Anyways, I have been looking around for a solution to my P0171 code on my 2000 Echo. I cleaned the MAF sensor with a q-tip and electronic cleaner (as suggested ). I also replaced the air filter. I then erased the code and drove around for about four hours. To my surprise, bam, it came back up again. N E other advice? I would hate to go to the dealer and give up my left arm. Anything would help. Thanks alot.
Are you sure it is a P0171 this time?
Look for a vacuum leak or Did you accidentally fill up with E-85 fuel?
Make sure the 2 hoses that go to the air cleaner lid and the VSV are properly connected or you will suck RAW fuel or fumes, this will set a P0171 lean code.
23 yrs with TOYOTA
Official Donahoe Certified Installer & Dealer
K.I.S.S.
