Originally Posted by DevinSixtySeven
that's the torque spec i found and used for the vacuum connection  ...it's the vacuum connector line bolt i couldn't find anywhere. kinda odd, since you have to pull it to get the manifold out.
Here is the pressure regulator torque spec, for the 2 6mm bolts.
But you dont have to remove it or any fuel rails or injectors
, only the 22mm for the fuel damper on the drivers side, where the fuel line connects.
As long as you got it changed
25 yrs with TOYOTA
