Originally Posted by mustang67408
Here is the pressure regulator torque spec, for the 2 6mm bolts.
But you dont have to remove it or any fuel rails or injectors  , only the 22mm for the fuel damper on the drivers side, where the fuel line connects.
As long as you got it changed
not that one either lol...the ring connector on the rear passenger side of the manifold, that links via air hose to the master cylinder. it was a 14mm gun and crossdrilled bolt.
