Old 12-18-2006, 11:19 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Default Re: "new" TSB for those of you who have had rear axle leaks
ive heard of a couple "friday" trucks...usually early models...
of course, i have an 00 and beat the crap out of it, and the drivetrain is still bone stock. i finally got a minor leak at the tcase companion flange a few months ago, probably the breather got clogged, the seal was worn, synth fluid is tenacious, and the belly skid keeps the heat in, so oil started getting past the seal.
nothing else has ever leaked...
the brakes youre looking for are bembro? brembo? whatever...slotted rotors and a set of nice pads...hawk, porterfield, or the stuff stoptech recommends. i had massive problems with the front brakes until i switched to aftermarket rotors and pads...havent messed with anything else in the brake department, the rear axle has never been touched except to change the gear oil.
-sean
GFX by FreedomEagle50
Manual Hubs
