Old 03-14-2002, 11:45 AM
5thwheeler 5thwheeler is offline
Last Online: 02-19-2008 12:32 PM
5thwheeler is on a distinguished road.
5thwheeler's Photo Albums
Default Re: towing horse trailer with tundra
Originally posted by KLS:
My Tundra's Owner's Manual, "Automatic Transmission (h) Good driving practice," pg. 100, says to tow with O/D off, When towing a trailer, in order to maintain engine braking efficiency, do not use overdrive. It also says, "If the transmission repeatedly shifts up and down between third gear and overdrive when climbing a gentle slope, the overdrive should be turned off."
I tow with O/D on and I only turn my O/D off when I get to an incline. In the mountains, I tow in second gear going up and down the mountain. If your pulling a trailer with any significant weight, engine braking in third gear, as refered to in the manual, is almost useless. It says nothing about the life of the transmission. If your looking for a great brake controller, get the Prodigy by Tekonsha. It is the most advanced controller on the market and it has made all other controllers obsolete. No need to hook ugly cables to the brake pedal (like you have to do with the Jordan Ultima 2020), and it makes for a clean installation. Mine sits in that little cubby hole right under the ignition switch. It is easy to read and very reachable. My Prodigy is gray and matches my dash perfectly.
