  #21 (permalink)
Old 12-29-2006, 04:08 PM
TS Support TS Support is offline
TS Support is on a distinguished road.
TS Support's Photo Albums
Default Re: File a complaint to NHSTA regarding VSC/ABS Skid control ECU failure
The following Brake related TSB's were issued related to the 2002 Sequoia
BR001-02 VSC RELATED ZERO POINT CALIBRATION AND SENSOR CHECK
1/11/2002 - 2001, 2002 Toyota Sequoia. The following information is intended to clarify the repair manual procedures for using the Toyota Scantool to perform zero point calibration and sensor checks after the replacement of any of the following components on a 2001 – 2002 model year Sequoia
BR001-03 FRONT BRAKE COMPONENT IDENTIFICATION (REVISED)
3/25/2005 - 2000, 2001, 2002, 2003, 2004, 2005 Toyota Tundra & 2001, 2002, 2003, 2004, 2005 Sequoia. There are two caliper designs that are in use for Tundra and Sequoia vehicles. The brake pads and fitting kits for these two calipers are not interchangeable. The pictures and parts lists below are intended to assist you in identifying and ordering the correct replacement pads and fitting kits.
BR005-02 FRONT BRAKE VIBRATION (REVISED)
3/5/2004 - 2001, 2002 Toyota Sequoia. Under certain usage conditions, some Sequoia vehicles may exhibit front brake vibration. Improved brake caliper assemblies have been introduced to correct this condition.
The only recall applicable to the 2002 Sequoia was SPECIAL SERVICE CAMPAIGN (SSC) – 50J FRONT SUSPENSION LOWER BALL JOINT
