  #33 (permalink)
Old 01-04-2007, 12:45 PM
otdaniel otdaniel is offline
Last Online: 01-04-2007 12:45 PM
otdaniel is on a distinguished road.
otdaniel's Photo Albums
Smile Re: Heat problem solved
Originally Posted by wizzer View Post
OK. I solved my porblem. Here is what hapened. The nut that holds the temperature control to thee front panel came loose. The knob and control started to wobble. This stressed the wires on back. Eventually 2 of the 3 wires attaching the temperature control to the cotrol circuit board broke. When the control knob was in certain positions one or both came into contact and the heat would come on.
I went to the dealer and they said "replace the heater contol unit." It costs $ 586.00 plus labor. I bought one from a junkyard for $ 75.00. I removed the bezel which surrounds the whole unit by gently prying it with a couple of screwdrivers. Be very careful not to sccratch the dash. Once that I saw that all connections to the back were electircal (3 plugs) I removed the old one. I opened it up and saw the broken wires. I soldered them, reinstalled it and it works fine now.
Anyone want a Heater control unit for a 2001 - 2003 Highlander for $ 75.00 plus shipping? It comes with the balance of the 30 day warranty.
Pictures attached.
I just ran into the same type of symptoms and I saw your post. I decided to take the dash apart and check the wires for the temp control. Guess what? You were right again! I fixed the connections and the heater works as good as the first day I picked the car up from the dealer. Thank you Wizzer, I really appreciate the help you have provided me (and that's not counting the $). Thank you.
