Old 01-05-2007, 11:50 AM
SMTRDSPORT's Avatar
SMTRDSPORT SMTRDSPORT is offline
Last Online: 01-04-2009 01:22 AM
SMTRDSPORT is on a distinguished road.
Send a message via MSN to SMTRDSPORT SMTRDSPORT's Photo Albums
Default Re: How To: Fog Light Modification
Originally Posted by mandzach View Post
Does this mod work on a 05+ with DRL's?
Yes, my truck that I wrote the write up on does indeed have the DRL option and this mod DOES NOT interfer with the running lights.
Originally Posted by George06TRD View Post
Someone needs to add what exactly this mod DOES. I can't find what the purpose of this is.
Meantioned above... With out this mod, the fog lights will only work while the low beam headlights are on. The foglights will automatically turn off during high beam operation. This modification allows the fog lights to be turned on/off using the fog light button as long as the ignition key is turned to the ACC or START UP position. Hense, you have the option of having your foglights ON during low beam use, high beam use, or just foglights only (DRL's will still operate as normal if your truck is equiped with that feature).
2005 Quad Cab Toyota Tacoma TRD Sport
Fabtech 6" Lift | Front: Fabtech Dirt Logic Coils w/ Fat Bob 1.5" Spacers | Rear: Fabtech Dirt Logic 2.0 w/ Reservoir | Alcon AAL w/ Skyjacker 4.0" Lift Block| Weld Velociti 6 XT | 35x12.50-17 BFGoodrich M/T | LEER 100XQ | K&N | Magnaflow Exhaust | Stubbs Sliders | TRD Goodies... but it's time for a new look I think...
