Old 01-08-2007, 05:12 PM
dyogim's Avatar
dyogim dyogim is offline
SAS'ed #5
dyogim's Photo Albums
Default Re: SAS on 02 tundra
It can range from $5K to $15K. Depends on the set-up, what parts you use and how much of the work you do yourself. Leaf spring set-up, is cheaper, coil over will be a lot more $$$.
Best thing to do would be to get a parts list together with the best prices you can find. Next determine what you do yourself and what a shop will need to do and get their prices. You'll also need to add the cost of all the nuts, bolts, washers, lock washers needed (grade 8 stuff) and include all the fluids.
I'm assuming you are using a D60 for the front, are you planning on changing the inner C's to kingpin (stronger) or staying with ball joints?
Another big question is how much are you willing to spend?
Mike
http://dyogim.blogspot.com
