  #36 (permalink)
Old 01-10-2007, 10:47 AM
Jack_MN Jack_MN is offline
Last Online: 01-10-2007 03:27 PM
Jack_MN is on a distinguished road.
Jack_MN's Photo Albums
Default Re: Heat problem solved
Hello. I have this exact problem on my 2002 Highlander. I actually talked the dealer into trying to solder these wires but the were not successful in getting the wire from the ribbon cable soldered, and because the whole process scared them to death, they gave up easily. Can somebody advise me on what size/type of replacement wire to use and what 'size' (how small?) of a solder gun do I need to do this? (I have no experience soldering).
Thanks,
Jack
Originally Posted by dfluitt View Post
Here are the photos documenting the heater control fix. The first shot is of the panel with the knobs removed. The nut that comes loose is under the knob and holds the shaft steady. The loose nut allows the small circuit board behind it to rock back and forth when the knob is turned causing the wires to break.
The second shot shows the back of the heater control unit with the cover removed showing the main circuit board and the small circuit board (circled) on the back of the control knob.
The third shot shows the ribbon cable where it breaks off at the solder joint on the small circuit board.
The fourth shot shows the three wires I soldered in place of the ribbon cable.
