Old 01-12-2007, 05:48 PM
monolithic's Avatar
monolithic monolithic is offline
monolithic's Photo Albums
Last Online: Yesterday 07:18 PM
monolithic is on a distinguished road.
Default Re: Blown Headlights because of auto starter?
Originally Posted by Kenai_Tundra View Post
After viewing your diagram and my manual I can see one thing I did not do. I wired the anti-grind relay, but I did not make the "cut".
Shorting out the anti-grind relay only allows you to grind the starter while it's running (it negates the anti-grind relay). It shouldn't affect the autostart's ability to know when the key is turned on (however, sometimes electronics designers do strange things...). If the wiring is correct, I'm starting to think there is an issue with the autostart itself. It could be that some auxiliary wire inputs are not present and so it's not working correctly (those wires not shown on the diagram I supplied - brakes, doors, etc.).
I let my subscription expire so I don't have access to 2002 wiring diagrams. If you do subscribe, they are available to you. Might help track down relay/fuse issues.
For 2004, there is a headlight relay, foglight relay, etc. that is controlled by the stalk switch wiring. These are located in the engine compartment on the driver's side in a black box with a removable lid and include fuses too. Your autostart should only be wired into the parking lights (not sure how its affecting the headlights). Any way you can disconnect the autostart and see if the lights work again?
2004 Toyota Tundra V6 Reg Cab 2wd Auto (Phantom Gray)
Options - Tilt wheel, Intermittent Wipers, AC, Mudflaps, Cold weather package, Bed liner (removed), Carpet floor mats, Trailer hitch receiver, Door sill protectors
Mods - Cruise Control w/factory dash indicator, Hellwig Anti-Sway Bar, Chromatic Mirror w/Temp & Compass, Phantom Gray Door Edge Guards, PT Industries Raptor SS Nerf for Access Cab, Fog Lights w/Factory Head Lamp Switch; Great Covers velour seat cover, 2004 Reg Base Cab Cargo Light Mod (use factory switch, no light when door opened), 2004 Reg Base Cab Auto Headlight Off Disabled Mod (lights stay on when door opened); SR5 Chrome Wheel Arch Moldings; Chrome power & heated side mirrors w/factory heat switch;Burlwood control faceplate & door switch panels; Overhead console w/garage opener & Luxeon Star LEDs; Alpex #244 Chrome dual air horns - 118db - 405Hz/450Hz - 15A; Horn baffle removal mod; Rostra Radar Backup Sensors;Pilot PL-250 Backup 55w Lights; H4 Osram Silverstar Headlights; Enkei Brawn II alloys; 245/70/16 Revos; Power Outlet Mod; Ltd Visors w/lights; RainTracker rain sensor; Factory power windows; Manik tail light SS guards #925659SP; Power door locks (DEI relay module 451M); ATS grill;ARE MX camper shell (full side screens & w/o vista window); CompuStar 2W900FM(S) Remote Start/Keyless Entry/Ignition Auto Lock;Bed Carpet Kit w/Couch & Storage Boxes; Pop&Lock PL8500 Pwr Tailgate Lock; WeatherTech Mats, TRD LSD
