01-17-2007, 01:56 PM
KE7WLF Master of Disaster
Re: Need wiring help with set of RAV4 OEM fog lights
Originally Posted by ecastrel
Mustang67405:
I am about to buy the Trendgear OEM foglights with the switch and "wiring harness?".
I was reading you helped ging with the relay switch:
- Do I need anything else other than the bulbs, oem lights, switch, relay?
- May i get the relay from you like ging did?
- May i please ask for instructions on how to connect them step by step with the diagrams like you provided ging? I didnt seem to find them through the forum, figured you might have sent them privately.
PM sent
25 yrs with TOYOTA
