  #44 (permalink)
Old 01-28-2007, 03:35 PM
Brian L. Brian L. is offline
Last Online: 10-15-2008 04:03 PM
Brian L. is on a distinguished road.
Brian L.'s Photo Albums
Default Re: Heater quit... sort of
Originally Posted by mm49 View Post
Got to the point where I undid the four screws, but you are right. I can't pull the unit out because it is stuck to the wires in back holding it in. How do I take it off? And more importantly, I don't see how i will be able to plug wires back in since the unit would have to be set in before wires could be plugged back in. Help!
mm49, Hey I'm doing this fix myself right now. After taking out the 4 screws also take out the six 10mm bolts Then the radio also comes out which gives you a bunch of slack on the wire bundle. then you can remove the 3 plugins. The 2 plugs side by side just depress the little tab while pulling the plug out. I used a scewdriver to help pop it out because the pugs are small and hard to get a good grip on. Just use twisting motion, doesn't take alot. The lager plug did not have a tab to push down but I used the same screwdriver method and it came out without too much difficulty. I have a hunch you have already figured this out but it might help somone else. Good Luck!
