Old 03-05-2007, 05:38 PM
Cliffy1 Cliffy1 is offline
Preferred Dealer
Cliffy1's Photo Albums
Last Online: 11-17-2008 10:12 AM
Cliffy1 is on a distinguished road.
Default Re: 06 Scion xB-Radio Servicing
Are you installing the factory receiver? If so, there's quite a bit that needs done, including removing the passenger seat. You will need to pull the radio, but that's pretty easy. Just pull the knobs off your AC controls (they just pop off with a little force) and unscrew the two phillips head screws underneath them. From there, you just give a good tug on the entire faceplate the covers the center of your dash. Then, you will see the brackets that hold the radio. It is held by 4 phillips head screws. Once those are out, the entire unit lifts out and you'll be able to access the plugs on the back of the unit.
Now a sales manager at Stafford Toyota in Stafford VA. Call 540-720-4700 and ask for Steve Clifford... they will not know who "Cliffy" is.
