  #35 (permalink)
Old 03-15-2007, 07:59 PM
mustang67408's Avatar
KE7WLF Master of Disaster
mustang67408's Photo Albums
mustang67408 will become famous soon enough.
Default Re: 2000 echo check engine light
1: make sure the spark plugs are not cracked or damaged (USE NGK or DENSO) DONT NOT USE BOSCH or DELCO or AUTOLITE
2: Clean or replace MAF
3: Make sure all vac lines are installed properly
4: check fuel pressure and take fuel sample to check for contaminated fuel
These are just guesses , as I dont have any SCAN TOOL info to go on when the car is acting up.
23 yrs with TOYOTA
Official Donahoe Certified Installer & Dealer
K.I.S.S.
