Old 03-16-2007, 11:43 PM
vancchris vancchris is offline
vancchris's Photo Albums
Last Online: 03-18-2007 06:39 PM
vancchris is on a distinguished road.
Default Re: Toyota SR-5 1986 Turbo
My understanding is that the turbo doesnt work at all. I dont get any smoke, the turbo light only comes on when i turn the key to start it up.
It does kind of sputter a little bit when sitting idle, and even when i give it gas.
-Never dies on me, its pretty dependable, in that respect.
Can you pull any codes?
as far as codes go.. im not sure what you mean. (i know very little about engines in general)
First i would drop the exhast at the header pipe INFRONT of the cat near the engine and then go drive it and see if that helps.
Plugs?
Plugs were recently replaced.
Fuel pressure?
Not sure how to check fuel pressure.
TPS set properly? so timing can be properly adjusted
TPS?
Thanks for replying!
