Originally Posted by Coner55
Joe...I tried to send you an email at your yahoo email addy but it got returned...im looking at a 4runner with 5/95 build date and VIN # JT3VN29VXS0087086...could you please look up this VIN and see if its already had headgasket replaced..and if its eligible...
the truck seems to have compression problems in one cyl @ 105lbs vs. 150 on other cyl...at least thats what a mechanic told the PO...
many thanks in advance...just trying to find my 16 yo son a decent car
scott
I tried to run the VIN but it says invalid.
Are you sure you wrote it down correctly?
JT3VN29V
(XS)0087086 These 2 letters I highlighted are not correct.
25 yrs with TOYOTA
