Re: 2000 echo check engine light
I couldnt agree more about the spark plugs. I changed the plugs on my 2000 Echo at around 60K and installed Bosch platinum. The car ran like it had liquified rat turd in the tank. The dealer told me about the Denso Iridium plugs the car had originally and that they would go 120000 miles. I went back to the dealer and 80 bucks later had a new set of factory plugs and all was well. I now use nothing but factory original parts in my vehicles and it is well worth it. Also has anyone else had an issue with a rear main leaking. Mine was changed at 70K along with the left drive shaft cause the dealer ruined it. This is the only real repair done in its entire life. Thanks.
B.T.W With 145000 miles this car still runs like new. I absolutely will not give this car up until it dies which may be never at this rate.
