  #16 (permalink)
Old 03-30-2007, 05:09 PM
DevinSixtySeven's Avatar
Leader of Group Evil
Last Online: Today 02:02 PM
Default Re: Air Filters: K&N/Fram Air Hog?
Originally Posted by chizel08 View Post
i prefer this K&N Filters for it has high air flow with excellent filtration, it is also economical since i washed them rather than replacing them, and when it comes to performance, it protects my engine with better filtration while providing more air flow and more power.
I hate to be a jackass but that's pretty much the advertising line on the box, and the first two and last benefits have been disproven over and over (even by K&N's own dyno charts for our vehicles), while the third is a moot point as the engine will take as much air as it needs and the stock paper is sufficient. Even the Trueflow guys will tell you all this...most gains are made in aftermarket intake kits on nor-am vehicles with poor OEM intake designs. Toyotas don't show much, if any, improvement from a filter alone.
The K&N I ran briefly...never caused a problem with the MAF from the oil, but it allowed quite a bit of dust down the intake tube, which did show up on the MAF when I swabbed it...so I guess you could say it could damage the MAF, but not from oil going downstream unless you soaked the filter in oil and then ran it hard. Incidentally that's consistent with this guy's test results:
Filtration Testing for Amsoil, K&N, Napa, Jackson Racing, Baldwin, and Mazda air filters on a Miata
And here's another interesting thread.
Bob Is The Oil Guy: Pics of cotten gauze vs paper under a microscope
For the record I've been using a TrueFlow filter for a while. I've also used K&N and stock paper in this truck. The K&N was garbage, for every reason mentioned in those two links. The TrueFlow seems to filter as well as the paper filter, but my super-accurate butt dyno doesn't suggest that it had any performance benefit other than catching a lot of dirt...I should probably clean it...
-Sean
GFX by FreedomEagle50
Manual Hubs
