  #33 (permalink)
Old 03-30-2007, 07:50 PM
nomolosTRD nomolosTRD is offline
Last Online: 06-13-2008 09:35 PM
nomolosTRD is on a distinguished road.
nomolosTRD's Photo Albums
Default Re: How To: Fog Light Modification
NOW TO OPTION #3:
Parts/Tools that you will need:
- Wire Strippers
- (3) Female Butt Connector
- Approximately 6 inches of wire (pretty much any gauge wire will work, doesn’t have to be anything crazy thick… 16-20 gauge is just fine)
STEPS #1-5
Find your light blue fog light relay, remove the relay and bend the top right pin from the relay to the side pointing outward, Attach a female butt connector to the bent relay pin. The other end of this wire will run to one side of a 5A fuse. Once you have your wire running from the relay to one end of the fuse, now run a wire from the other side of the fuse to the red 10A fuse that’s located directly to the right of the relays location.. Now you’ve completed this modification. Something you might note doing this modification this way, I’ve heard that in some cases if the fog light button is left on, your fog lights will sometime have a tendency to flicker on/off after 4-6 hours of sitting. The fog lights evidentially will come on for a minute or so then turn off repeating this process every 4-6 hours…
I Did this mod some time ago and it caused my check engine light to come on, do you know why it would do that? Has it happened to anyone else?
