Re: Drive shaft grease fitting
I called another dealer and questioned the drive shaft situation on my DC. He agreed that the 4wd has the grease fittings, and that with the 4wd sitting a little higher, the shaft moves more in and out of the yoke , which in turn can cause the need for grease more often. He said on the 2wd that it is a sealed yoke, and that it should not ever need grease. Obviously he is mistaken. Also, he said that Toyota will not put a grease fitting on it for me. I guess I am back to taking matters into my own hands. I just have to find out where to put the fitting, I can handle the install of it.
Mike
2008 Tundra Crew Max SR5 , Pyrite Mica, SS Steps, Fender Flares , 20" Limited wheels w/305/50/20 tires,
Alarm system, Sirius radio
