Re: octane: u running 91 or 87?
If you dont run the recommended 91, it will lack power and not achieve the best fuel economy. This engine is designed to run on 91 for a reason. Its all about combustion chamber design and emissions, while trying to squeeze the most power and MPG per gallon.
The use os anything lower may not hurt it, but you wont be at your full potential.
25 yrs with TOYOTA
