  #35 (permalink)
Old 05-01-2007, 03:14 AM
toku58's Avatar
toku58 toku58 is offline
Last Online: 08-30-2009 07:01 PM
toku58 is on a distinguished road.
toku58's Photo Albums
Default Re: How To: Fog Light Modification
I finally got around to doing the fog light mod.
I wanted to easily be able to pass safety check. So I did it a bit differently.
So I installed a SPDT (Single pole double throw) Rocker switch ON/ON.
That basically means that it's a switch that allows me to select power sources. One way is constant power, and the other way is powered exactly as factory!
Any ways? I tried to do the wiring from the bottom of the fuse block but it was a birds nest under there! Too much trouble so I just did it the "getto" way. Best thing is that it is easily reversed back to stock. No one would ever know I did anything. (But I'll do it from underneath when I have more time.)
Here's the wiring:
Here's the rocker switch:
Everything works like the regular fog light mod! Just that with a flick of a switch it can work just like factory fogs!:clap: :clap:
Here's the print for the fog: BEFORE
AFTER:
The red line would be the ON/ON rocker switch.
Fabtech lift. 35x12.5x17 BFG KM2
http://www.cardomain.com/ride/2435980
