Originally Posted by ejsfj
this is an old and extensively covered topic go look back in the threads about 6 months and you will find all the info you need (and then some). Long and the short, nothing gained by running prem. I haven't run prem for about 10000 miles, no difference. Sorry Musta....whatever you called yourself, prem doesn't matter on this truck. Other cars do need it, just not this one.
I disagree, but thats what makes TS so great. We can both be right
In our own worlds.
Toyota does alot of R&D and says it needs it for a reason.
I wont beat on this, your right. It has been covered before.
Enjoy the cheaper 87. I HAVE to run 91.
Have a good weekend
25 yrs with TOYOTA
